Downdraft table questions
goodhue1
Post by goodhue1 »
I bought a used plasmacam last week and my new air compressor is coming tomorrow. I just need to put together a ventilation system. My main concern is loosing all my near from the shop. As I type this it is -15 out and I feel like if I had a fan running I could suck all the heat our of my little shop in 30 seconds. Do you guys have any tips for me as I figure out my ventilation? Thank you!
Re: Downdraft table questions
Post by tnbndr »
Look into a water table instead of ventilation exhaust. There is lots of info on this forum.
KIDTech
Post by KIDTech »
A lot of it has to do with how much money and time you want to throw at it. I have down draft only, thinking about doing a drip feed that rides the gantry putting water on top of the metal as it cuts.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
SONIC
Post by SONIC »
Water table for sure.
There's no way to ventilate the table without sucking the air out of your shop, unless you made a separate booth/room that was vented to outside air for the table.
I run mine inside all day with the water table with no issue
allan101
Post by allan101 »
I have set up a smoke extraction arm that I scavenged and hooked it up to ventilate into a smoke and fume filter it works awesome. All my heat stays in the shop I have mine mounted to a i beam with trolley wheels so I can move it around
and it is off the floor
