Question on muriatic acid
csmith
Re: Question on muriatic acid
Post by csmith »
be aware that the fumes will corrode metal surfaces, so keep it ventilated, preferably outdoors
Digiroute 500 CNC Router (3x5 cutting area)
Deltacad 7
Vectric Aspire 3.5
Mach 3
metzindustries
Post by metzindustries »
Here it is 7 dollars for a gallon of 25% or about the cost of one American made flapper disc.
I just pour a little in a plastic tub about one inch and another inch of water. Using goggles, rubber gloves and apron.
45 minutes removes my mill scale, the dross takes much longer.
To stop the post acid rusting, I have a second tub with baking soda and water. I neutralize the acid, then wash with plenty of water.
Then I hit it with a flapper disc to remove that grey powder looking stuff. It will stay rust free for a couple weeks even here on the tropical island.
I also found that longer soaks make the corners rounded which is nice when doing lettering to give them more of a cast metal look.
muzza
Post by muzza »
metzindustries wrote:I just pour a little in a plastic tub about one inch and another inch of water.
Just a note, you should always add acid to water, never water to acid
Murray
signsbyhansen
Post by signsbyhansen »
There is no way that I could store this stuff outdoors. We live in -40C weather. Any suggestions for storing indoors?
Thanks in advance.
rottenleonard
Post by rottenleonard »
So I have about 4 gallons of this stuff that seems pretty used up, it no longer effects the metal, and if i put a little baking soda into it it doesn't foam. I would add more acid but my resivour is full. what can i do with this? can it just go down the drain? or in the driveway? or would I be causing a ecological disaster?
modelaratrod
Post by modelaratrod »
Does anyone have a part # or brand of Muriatic acid? All I'm finding is "safer" than Muriatic acid, and the usually translates into doesn't work as well. lol
Thanks.
5x10 Torchmate 2 w/AVHC
Hypertherm PM85 w/ machine & hand torch.
kbenz
Post by kbenz »
modelaratrod wrote:Does anyone have a part # or brand of Muriatic acid? All I'm finding is "safer" than Muriatic acid, and the usually translates into doesn't work as well. lol
Thanks.
Lowes http://www.lowes.com/Search=muriatic+ac ... iatic+acid#!
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
VPT
Post by VPT »
Does white vinegar freeze? I live in WI and am trying to figure out what to do for cleaning parts.
Post by tnbndr »
Put a bottle of it in your freezer and find out? My guess is that it will as it is mostly water!!
I keep mine in the basement.
