Cad and dxf
Cad and dxf
Anyone got advice on Cad? Which ones are good at both mechanical drawing and working with DXF files? Turbocad? Free cad? Inkscape? Draftsight?? Iv'e got Corel draw X6.Not really user friendly for mechanical.
Re: Cad and dxf
@othill
I use QCad Pro. I may not be a good person to comment as it is the only program I have ever used. Friend of mine also uses it and he can make it do some incredible things. I think all cad programs have a steep learning curve. I do like the program.
Dawson is a beautiful part of the country, long time since I was there.
home built 4x4 watertable. Qcad, SheetCam and Linuxcnc
Miller 375 Cutmate
Lincoln buzz box and a Miller Mig
KNK MAXX vinyl cutter
The adventure started with a Cricut cutter that I hacked.
Miller 375 Cutmate
- WyoGreen
Re: Cad and dxf
I use SolidWorks, they have a free version. You have to renew your registration every year, but other than that it works good. With that said, I rarely use it, as Corel Draw works fine for almost everything I do. I find that by typing in Square sizes and Circle diameters, along with using guide lines, I can make up drawings that are within the tolerances that plasma can cut.
Router
Laser
Router
Laser
Re: Cad and dxf
I use Inkscape and TurboCad and looked at Qcad as with any software there is a learning curve. The terminology seems to be the problem as they have different names for operation used to do things. There are large numbers of tutorial type videos on the web that help and the old lets see what this does process, and the un-do edit key helps in learning. As that Inkscape and QCAD are free how much you can spend seems to be the factor on what you get and use. Some of the high end CAD programs may have more fetchers and quicker doing things after you learn them.
Re: Cad and dxf
Thanks for the info.I have recently bought another plasma table and when I get it going my son and his boys are going to use my first table in their shop.I was looking for something more user friendly for them but might just have to go the Corel Draw route.
Re: Cad and dxf
Draftsight is basically a free clone of Auto Cad, I have both and tend to use Draftsight much more often, it's less cumbersome and does a much nicer job on text conversions.
Bill Hamer
BHamer62@comcast.net
