I'll start off with mine;
One used the most would be this for holes, it was mentioned on the forum by someone else about using this method, it works well to cover different size holes using the one rule.
This one I use to slow down the feed as the flame crosses over the leadin as it tends to jump over leaving a tag stopping the part from dropping out (Powermax 45), you have to play about with the right area to catch that bit, works well for me at these settings on thicker material, 10mm upwards.
The idea with using 99.8% feedrate is so then the rule shows up a blue line.
Also using tangent leadins gives you that straight corner leadin (took me 18months before I sussed that one
