Rigid Shaft Coupler Source?
urbnsr
Post by urbnsr »
Does anyone have a somewhat inexpensive source for the steel one piece rigid shaft couplers? I need a handful of them from 1/4" - 1/2" and find prices in the $50-75ea range. I thought I bought one last year that was priced maybe half of that, but not finding the paperwork on it. I like how they grip so well without gouging the shafts.
Thanks for any direction....
Paul
Re: Rigid Shaft Coupler Source?
WyoGreen
Post by WyoGreen »
I have bought shaft couplers from Mc-Master Carr, you might take a look at their prices.
http://www.mcmaster.com/#standard-shaft ... gs/=zyra7o
Router
Laser
urbnsr
Post by urbnsr »
Thanks for the info. I actually started with McMaster-Carr, but must have looked at the stainless steel column. Steel column looks better, but still room for improvement ;)
WyoGreen
Post by WyoGreen »
Ya, they're not cheap, but they do have almost anything you need. ;)
Router
Laser
urbnsr
Post by urbnsr »
I agree. And shipping time is quick, too. In the end, I probably won't even think twice about the cost as well as they work.
gary42095
Post by gary42095 »
try amazon. i have purchased a few ruland couplers from 1.25 bore for 60 bucks or so. smaller should be a bit cheaper
bhamer62
Post by bhamer62 »
Do you have a local farm supply store like Tractor Supply? These coulplings are made by Ruland and Nomar. Also try your local industrial power transmission supplier, your local bearing, sprocket and chain house.
urbnsr
Post by urbnsr »
Good ideas. I did look through Amazon a bit, but I didn't think to look in my own back yard at the tractor supply stores. One place did surprised me with their Quincy air compressors.
Thanks...
muzza
Post by muzza »
I bought some for one of my tables on ebay here in Oz last week for $10.50 each so I expect they'd be about half of that in the US.
Murray
urbnsr
Post by urbnsr »
Thanks Murray,
I revisited eBay USA and found $10 couplers. They have one clamp screw per shaft and I can't say that isn't enough to hold. I'll give them a shot. Thanks again...
PK
Post by tnbndr »
I just ran across this post in another forum. Worth a shot.
http://www.pirate4x4.com/forum/miscella ... arket.html
