pierces all over the place before cutting
kcarpenter12
Post by kcarpenter12 »
Everytime I do this file sheetcam creates lots if start points besides the inside and outside cuts. on both of my cad programs it isn't showing any open contours, and it seems like all the lines are connected, but when I do my cut paths it goes crazy. Anybody know whats going on and can help? here is the file
kcarpenter12
Re: pierces all over the place before cutting
welcome outdoors small pattern.DXF
East German
Post by East German »
I hope this help
Please restore the size
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
kcarpenter12
thanks it looks like it will work, can you tell me what I had wrong, and what software you used to fix it. thanks
East German
There were individual lines are not closed contours. With VCarve Pro 5.5 everything connected.
MyPlasmCNC
Machine Torch
Machine Torch
WyoGreen
Post by WyoGreen »
I took a look at your DXF. There were 4903 individual lines in the DXF. I used Cam-Bam to join the the lines into 25 Polylines.
welcome outdoors small pattern2.dxf
Router
Laser
_Ogre
Post by _Ogre »
i'd rather teach the man to fish than give him a fish :mrgreen:
i opened your dxf in sheetcam
the first obvious problem is various line segments on 3 layers
by turning on/off various layers in sheetcam you can see this
you'd also have to set up 3 operations to completely cut all lines
i opened the the file in autocad and changed everything to 1 layer
reopened in sheetcam and all is good, there were no open segments or corners
that's what's going on and how to fix it next time you run into this problem
not sure how you could change all segments to one layer quickly in sheetcam
maybe someone can post up a quick sheetcam fix to merge the layers
vmax549
Post by vmax549 »
In sheetCam you would use select all from all layers then move to a layer.
(;-) TP
_Ogre
Post by _Ogre »
what did i tell you :mrgreen:
to clarify... click on edit contours icon: arrow with C
right click on screen to see the menus available
thanks vmax :mrgreen:
Return to “SheetCam”
