Corel draw x6
OTHill
Corel draw x6
Post by OTHill »
Can any body tell me if I can Load x6 into a new computer and also keep running it in the old one?
Re: Corel draw x6
Post by tcaudle »
As long as you have the license you can load i on multilpe computers. Is it leagal under the license ....probably not. Will it call the osftware police on you ...probably not.
Gamelord
4.5 Star Member
4.5 Star Member
Re: Corel draw x6
Post by Gamelord »
You may have a difficult time loading both X6 and an older version on the same system as they both will try to use the same drivers and one may overwrite the other which may screw the other up.
Nearly everything is backwards compatible with Corel, so loading X6 should be totally compatible with anything drawn with earlier versions. That being said, I don't know why you would want to use an older version if you have the newer one available.
OTHill
Re: Corel draw x6
Post by OTHill »
Thanks both of you I got it done. Gamelord I'm talking different computers not different versions of Corel.
