Here is a video where the guy designed a sign for a customer in Fusion 360 that has other info that may be useful to some.
have fun Tom
Sign video with other info
Re: Sign video with other info
Thanks Tom, will check ity out. Always looking for new Fusion tips
- ROKCRLER
Tom you beat me to it... i saw his video last night.
Definitely a lot of good info on layered signs and mounting. I ordered stand offs based on what he used, theres also an aluminum sign he made in a different video that explains a lot on layered signs.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Never know what you will find sniffing around YouTube
Thanks for posting this Tom! It's always great to learn a little bit more about Fusion 360.
A little different twist for the guys doing signs, this is an idea that just popped up in my little brain. It is using clear epoxy pour to cover a sign or wall hanger you have made. This will put a very shinny finish to the project as show in the attached images. Now this is slightly different as this is a plaque which was routed from 1/4" MDF but I see not reason a metal one would be any different. I used epoxy from Home Depot (2 part) like this.
https://www.homedepot.com/p/FAMOWOOD-1- ... /301826159
The project needs to be very level for the pour process and I use a small acid brush to move the epoxy around to cover the whole surface, it takes about 24 hours to fully cure. I tried to show how reflective the finish is in the images.
