Probably a basic question but I missed spot welding day, I don't know much about spot welding except for what I learned many years ago for sheet metal thin to thin. I need to weld some very small 20 gauge strips to 3/8' rod. I need to do it quickly with little fuss.
been thinking about spot welding it but I don't know the first thing and my usual google searches are not getting me what I need,.
so best way to attach a 1/4" wide 20 gauge strip to 3/8' square rod? Can I just use a cheap spot welder? Also need to bend the overhanging ends up. They are tabs to hold something.
I have a working solution but it is fussy and slow and not ideal. thanks,
School me on thin to thick spot welding
Re: School me on thin to thick spot welding
try posting the question on https://weldingweb.com/vbb/
Weld engineer here....
Don't do it. cheaper and easier to drill a hole and plug weld it.
As current flows through the two faces, the 20g sheet will melt and push away before the .375 rod even starts to sweat.
Cheers.
Cheers.
that's were i eventually got to.
