STEEL TREAD PLATE
pdjcutandfab
STEEL TREAD PLATE
Post by pdjcutandfab »
I'm trying to cut a sign out of 14ga steel tread plate and i'm having trouble, the torch seems to start the cutting process ok but part way thru it shorts out, then re-ignites and continues to cut. I'm getting frustrated b/c I seem to have trouble burning larger items. I'm not sure if the material is warping as it's cutting (I do have a couple clamps holding the material down). Any help would be great
Pat @ PDJ Cutting and Fabricating
(39.17 KiB) Downloaded 205 times
(53.26 KiB) Downloaded 205 times
(46.62 KiB) Downloaded 205 times
KenTexFabrications
Re: STEEL TREAD PLATE
Post by KenTexFabrications »
I do not know if this may help you, but I always cut tread plate the old school way. Turn the tread facing down and try cutting it from the smooth side up. I just mirror my dxf's before g-code. Hope that makes sense.
KenTexFabrications ;)
pdjcutandfab
Yeah, that's how I tried it the 1st time and that didn't work, I think i have some other issues with my setup
