rounded corners
curlyweld
rounded corners
Post by curlyweld »
I have cd 3 and cd 4 and use them for my cnc plasma cutting, they do a great job. I want to know how come some times when I try to radius four corners they curve evenly and sometimes they don't ?? I'm thinking it's just some small thing I'm missing. Someone set me straight,,,,,,,,,,,THANKS ,,CURLY
JJsCustomDesigns
Re: rounded corners
Post by JJsCustomDesigns »
i wanna know too. Squares turn out nice. But rectangles look like crap.
on Rectangles ill make a circle the diameter i need and place em in the corners and delete everything but the diameter i need. Then weld it together.
PM me with details
jmsrbrt
Re: rounded corners
Post by jmsrbrt »
Works fine for me in TM Cad.
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
Gamelord
4.5 Star Member
4.5 Star Member
Re: rounded corners
Post by Gamelord »
Not sure what you are doing, but in Corel Draw, if you draw a square, it keeps it as a square. When you try to edit the corners of the square, it effects all four corners the same. If you take the square and convert it to curves (right click on the square, select "convert to curves" then you can edit the square and all the nodes independently of the others.
This may be what is happening to your drawings. Some of the boxes are not actual squares/rectangles but instead, curves attached to look like a square. If the drawing is an actual polygon, you can edit all four corners equally. If it is not an actual polygon but a drawn object, each corner will be edited individually of the others.
If you are in Corel and want to round a corner on a non-polygon object. Click the "node" editor tool (second one down from the picker tool), then select the object to edit. You should see the nodes of the object become visible. Double click on one side of the corner where you want the curve to start and it will add a node. Then double click on the other side the same distance as the first, it will add another node. Then select the node in the corner and delete it. It will draw a straight line between the two new nodes you created. Then select the straight line in the middle with a single click (don't add a new node here). Then select the "curve" icon on the top menu bar to change the line from a segment to a curve, then select the line and drag it to the curve you want.
If you are not using Corel, or if this is not the info you were looking for then sorry for side-tracking the topic. :)
Torchmate CAD
JJsCustomDesigns
Re: rounded corners
i thnk what hes is saying ( happens to me too ) is when you draw a square, before you convert to curves, you can take the node tool and click the object. Grab a corner and drag and itll pull all 4 corners into a nice radius. If you have a rectangle and try to do the same thing. It doesnt work so well. The longer side of the rectangle has more curve than the shorter side. Im wondering how can you make this corner proportional without taking the time and welding in circles.
I wish i was on the shop computer... id take screenshots of what i'm getting at.
PM me with details
Gamelord
4.5 Star Member
4.5 Star Member
Re: rounded corners
Post by Gamelord »
You can manually set the curve of your rectangle.
When you draw your rectangle, select the pick tool (top main tool) and select the rectangle to edit. On your top menu bar, it should have all the settings for your rectangle...ie...vertical size, horizontal size, rotation and corners. You can set the style of corner radius as well as the amount of radius on each corner. If you select the little "paddle lock" icon, it will either lock all four corners and make them equal, or unselected -will allow you to set each corners radius individually. Enter in your dimensions and hit enter and it will round your corners.
Hope this is legible.  Using Corel X5
Torchmate CAD
Gamelord
4.5 Star Member
4.5 Star Member
Re: rounded corners
Post by Gamelord »
Once you convert the square to curves, the nodes will not automatically adjust and re-sizing the square will change the curve so it is not equal.
If you want to change the size of your square after you have rounded the corners - and after you have converted the square to curves you can do that this way:
1. Select the square to edit.
2. Select the "Node" tool to display the nodes in the square.
3. Drag around and capture all the nodes on the side of the square you want to re-size or stretch.
4. Once the nodes that you want to edit are all selected, then click and hold on one of the selected nodes in the group and drag the entire group to the new size.
5. *optional* Hold the "CTRL" key to lock the movement while dragging all the nodes together to the new correct size.
This will allow you to change the dimensions of your square after it has been converted to curves without changing the amount of curve you have pre-set in the corners.
Hope that helps.
Editing Nodes to re-size squares without changing the radius.
Torchmate CAD
JJsCustomDesigns
Re: rounded corners
curlyweld wrote:I have cd 3 and cd 4
i also have CorelDrawX4 ---- your pics show X5.
but i understand what you did there... Ill give it a shot. Thanks
PM me with details
