what did i do to my autocad? settings?
AutoCAD and Fusion 360 related questions, tips and topics can be posted here
gary42095
Post by gary42095 »
i have autocad 2004 and have no idea what settings i have changed. if i left click on part of an image to select for a specific layer or multiple lines circles ect, then i right click to get the popup menu to deselect it just undoes automatically. if i right click again it opens help menu. i must have changed settings but not intentionally. if i try to close file it says
autocad cannot close document because there is still a command active please complete command and try again. it seems that my right click repeats whatever i did last only while in autocad
help please
tnbndr
Re: what did i do to my autocad? settings?
Post by tnbndr »
Go to your Tools/Options/User Preferences and edit the "right click customization". I think there is a check box that says if no command active right click means repeat last command. Autocad is funny this way, changing settings randomly. Hope that works.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
gary42095
Post by gary42095 »
Exactly the problem thank you i would have never found it because i never messed with anything
Return to “Fusion 360 & AutoCAD Forum”
