Parts Tumbler Build (with pics)
Re: Parts Tumbler Build (with pics)
Post by BrianMick »
Here is the one I built. I used a 1/2 hp electric motor(if I had to do it again I would use a 3/4 or 1 hp motor) a pully wheel off of an old cement mixer(that is what i used to use until it wore out) and the baldor variable speed controller(was probably the most expensive part...around 450.00 usd ) the motor has to be variable speed also. Plasma cut the octogons and barrel sections out bent them into two halves and welded all together with 1 inch roundbar in the center( which turns on two pillow blocks) Did not weld any fins inside as I figured the flat sided style would force the material to flop on each other. I also put a timer on it so that it would shut off after as long as I wanted so parts dont get tumbled too long Works great
mdwalker
Post by mdwalker »
Not sure if I have any pictures but I made a ball mill a few years back. I used the transmission from an old riding lawn mower for the gear box and a 1HP electric motor. I worked perfect and I could change the speed by shifting gears.
Danny
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
redneckgateart
Post by redneckgateart »
@ Danny : Until I remembered having the gearbox, we were thinking about the lawnmower transmission idea too. We even thought about keeping the engine....it might've made enough racket to cover up all of the noise!
@Brianmick : Cool build! I like the timer idea!
motoguy
Post by motoguy »
The majority of these photos won't load for me. Maybe too old. Anyone have anything similar?
DesertFabworks
Post by DesertFabworks »
I can not see the first set of pictures either. I use a cement mixer that I got of craigslist. Tough to beat for $50. The built by BrianMick is nice though.
Desert Fabworks LLC
Fort Mohave, Arizona
www.desertfabworks.com
Follow our CNC Plasma Build:
www.cncplasminfo.com
Follow our CNC Router Build:
www.cncrouterbuild.com
HaasMetalDesigns
Post by HaasMetalDesigns »
I ben thinking of making on myself but never used one could someone post a before and after pic of there parts and what else do you put inside of it?
East German
Post by East German »
Hallo
This is my Garden Earth and Parts Tumbler is an old cement mixer.
The parts were 15 minutes in.
Works fine.
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
BTA Plasma
Post by BTA Plasma »
That worked out VERY well!
BAR M
Post by BAR M »
Peter,
What medium do you use in your tumbler ?
I have tried sand and later small, .75in stones, but none compare to your results.
Thank you, Bob
East German
Hello
see this:
https://plasmaspider.com/viewtopic.php? ... er#p162599
Only parts come in, the parts are cleaned well thanks to the hard grille.
Peter
MyPlasmCNC
Machine Torch
Machine Torch
cstroke
Post by cstroke »
Has anyone tried media to polish items?
I have a bunch of stainless steel parts that I absolutely hate grinding. Wondering if I could choose a media to give it a DA style finish???
any thoughts?
Chris
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
robertspark
Post by robertspark »
I wonder if garnet would work? I use garnet (30/60) in my sand blaster and it has worked very well for steel and aluminium. Glass beads I've used for aluminium too but they would be too soft for steel I expect
TrinityFabworks
Post by TrinityFabworks »
Has anyone tried to put black diamond media in a tumbler before? I know that it's for blasting, but It's so cheap and it's really course, I just wondered if it would work. Just picked up a tumbler yesterday and thought that I might give it a try.
abmetal
Post by abmetal »
I've tried black diamond but it didn't work very good for me. It's pretty inexpensive so I'd say give it a try.
Allen
