I do these names for a custumer who wants me to use Century Gothic Bold Font.
If you look at the file the "G" is taller than the other letters. Same happens with c,s,and o.
My question is how can I select only the "G" and resize it the same height as the other letters?
Thanks, Jim
X5 QUESTION
X5 QUESTION
- Attachments
- EDD & FAYE GILLEY.cdr
- (389.65 KiB) Downloaded 62 times
Re: X5 QUESTION
while it's still artistic-text, you can use the text tool to select the letter G and adjust the font size, font adjustments only affect the selected text
or, before welding it all to the rectangle, you can convert-to-curves, then break-apart, then scale the G, just be sure to combine all the loose text parts back together before welding to preserve the holes in the letters
Re: X5 QUESTION
Gary, thank you for your help. Your so helpful on this we site.
Jim
Jim
