Powermax 85 vs. 3/8 HR
Dawgonhawg
Post by Dawgonhawg »
Going to cut my first piece of art from 3/8 HR. Any tips or suggestions will be appreicated.
Thanks, Jim
Re: Powermax 85 vs. 3/8 HR
Post by jimcolt »
Assuming you are cutting on a cnc machine.....use the 65 amp shielded consumables, follow the machine cutting specs exactly.....use the consumables listed (especially the machine torch shield) set the pierce height, pierce delay, cut height, and use the recommended (not maximum) cut speed.
Jim Colt
