New Duramax torch on 1650
Is there a cut chart for the Duramax retro on a 1650 machine? I use it at 100 amps quite often. Or should I use the standard chart for the 1650 normal machine torch?
Re: New Duramax torch on 1650
The cut charts are loaded on the DVD or CD that ships with every torch.....the charts are quite different as compared to the original specs for your 1650....so they must be used for best performance.
If you have misplaced the disc....you can go to the Hypertherm website, go to the Duramax retrofit torch section, go to downloads, and download the .pdf file of the torch manual. The detailed cut charts are in the manual. Here is a link:
http://www.hypertherm.com/en/Products/H ... pgrade.jsp
Thank you, the shop I purchased from must have misplaced the cd as it wasn't with the torch.
