need help converting this picture. But i would like you to share with me the steps you used whether in corel or other so i can learn instead of having someone just do it for me. Thanks
Need help converting picture in Corel
Re: need help converting picture
I would like to replace the bull with this bull and rider.Or just put the clown in front of the bull rider if that's possible?
Thanks-
In Corel, use the pencil tool to draw around what you don't want (red line) then use TRIM command to get rid of that part, then import the new bull, arrange shapes with overlap, then use WELD command to join overlapping elements.
- Attachments
- SignTorch Vector Graphics
- rodeo_clown1.gif (4.93 KiB) Viewed 1134 times
Great thanks Gary, I will let you know how it comes out.
Yep i really dont know what im doing. Cant even get the pencil to outline. I cant even get the pencil on the screen. Corel draw x3. Im about done with all of this.....................
my bad, corel has several pencil tools, none are named pencil, I usually use the one called FREEHAND TOOL, it draws one segment at a time, then you can click on either end point to start the next segment connected, when done click on the first point to close the shape, and if you click and drag it will draw a curve rather than a line segment
but if you mis-pick and deselect the shape then new segments won't be attached, you have to have the shape you want to add onto selected, then the end nodes have a little click box showing, if you don't click on an end point of a selected object with a click box showing then it will start a new detached segment
if you do end up with two or more separate segments that are supposed to be joined, select them, then COMBINE them, then use the node tool to select two nodes to join, then right click on one, then hit JOIN
that's tricky, having to combine segments, then join their end nodes, in order to connect them, it's good to practice all that before starting a project, otherwise it's sure to be frustrating and confusing
there's really only a couple of tools and a few commands that do most of the work, once you understand their intricacies, it's not so difficult
- Attachments
- signtorch.com
- freehandtool.gif (13.01 KiB) Viewed 1118 times
- signtorch.com
Good info.
