locating objects on Xand Y
trucks1948
Post by trucks1948 »
If i'm drawing something like a bracket that has holes at certain x and y spots .How do i set these holes up to be exactly on the spots they need to be.Hope i explained this clear enough.I am using corel draw X5.thanks Jim
SignTorch Vector Art
Re: locating objects on Xand Y
Post by SignTorch Vector Art »
by default the origin is at lower left of page, see menu tools/options/document/rulers to change the origin
select the object(s) to move/copy, then use the position tab on the transform docker (menu: window/dockers/tranformations/position) to move/copy the selection
Transform/position docker
enter your coordinates in H and V inputs, uncheck relative position to enter absolute coordinates (relative to the origin), use the 9 way checkbox to set the base point position relative to the selected object(s), set copies=0 to move the selection, else it will make copies of the selected object(s)
if windows/toolbar/property-bar is checked, that toolbar has X and Y position inputs (same as H and V)
property bar
property bar
property bar
for circular placements, use the rotation tab on the transform docker, or rotation input in the property bar, works similar to positioning, except to set an arbitrary base point for rotation, click the selection to activate rotation handles, and drag the center mark to the desired center of rotation, before applying rotation.
trucks1948
Thank You I'll practice it.jim
