Cutmaster 52 hand torch - cut quality
NorthridgeFab
Post by NorthridgeFab »
I have a plasmacam and am running a CM52 with the hand torch. I am using a homemade ohmic sensor.
Plasmacam tech said to use the TD machine shield and retaining cup. Will this help cut quality or just enable the use of the TD ohmic clip?
rock4xfab
Re: Cutmaster 52 hand torch - cut quality
Post by rock4xfab »
I doubt cut quality the sheild cup does just that keeps crap from blowing back a the nozzle, so it may help with consumable life and may play a roll in the OHMIC switch But I dont know for sure.
weldguy
Post by weldguy »
If they are suggesting to use the shielded consumables shown below I have not had much luck with them at all. Those shield cups cause more problems than there worth. I only use them when cutting plate 3/8 and thicker to protect the tip from slag blowing back at it.
I believe the TD ohmic clip can be used on your existing consumables.
rock4xfab
Post by rock4xfab »
The above pictured is what I use on my setup no issues..
prattswelding
Post by prattswelding »
I'm also using a Cutmaster 52 with an SL-60 hand torch. I purchased the Ohmic Clip, shield, cup, etc. shown below. When I tried using the shield cap, I get the error "Torch Hit Material During Travel" message when the torch is several inches above the material. I can't even move the gantry using the travel command without this error coming up. When I remove the shield cap, this message stops.
My main complaint with the ohmic clip is that it only touches one small spot on the plate. When it would go over a spot that had already been cut and the material had dropped out (say 3/4" of an inch from where I was making my current cut), the machine would keep lowering until my tip was dragging the plate. I went back to using a home made sensor that makes a loop around the entire tip. This way I have a sensor on all sides of my torch. I made it out of 3/32 stainless tig wire. it does collect dross after a while, but it flakes off easily with just my fingers. I generally run my Arc Voltage Shift at 8.5, and that holds my tip around 1/8" from my plate. Hope this helps a bit.
