HEY GUYS WE HAVE A TORMATE WITH HYPERTHERM POWER 45
WHAT DO SETTINGS NEED TO BE TO CUT 1/4 PLATE
THANKS, P. WALKER
TORCHMATE WITH HYPERTHERM POWER45
- admin
- Site Admin
Re: TORCHMATE WITH HYPERTHERM POWER45
Best to check your manual for cut speed, pierce delay time, and arc voltage. Are you seeing problems with your cut quality?
Will move this thread to the cut quality section since it is not DXF related.
Best Regards
Admin
Best Regards
Admin
Follow the cut settings under machine torch cutting in your Powermax45 manual, use the optimum (lower) speed settings for best quality. Assuming you have a torch height control....start with the arc voltag listed in the chart, then adust to control the torch to work distance to the recomended .060". Don't worry if the voltage is not exactly what is listed in the chart...the physical height is more important. Too high and you will get excess bevel and dross.
whs92 wrote:HEY GUYS WE HAVE A TORMATE WITH HYPERTHERM POWER 45
THANKS, P. WALKER
