Exhaust
Exhaust
Any files for custom tips and stacks for pickups?
Re: Exhaust
What kind of pickups? Perhaps post some photos showing similar. Are you looking for actual part files or artistic type files to use for plasma cut artwork?
Re: Exhaust
Example
Re: Exhaust
Re: Exhaust
Thanks DieselFumes! Here are some screen shots showing the basic sequence for creating this part using Fusion 360 and Design Edge. The part I did using Design Edge could just as well be accomplished with one of the other cad drawing programs.
The really cool thing about this design approach is that once the Fusion 360 program is completed, any of the the dimensions can be changed "on the fly" to produce a new flat pattern. For example - say you want the part longer, wider, a different cut angle, different size transition cone, different size exhaust tube, etc. Very easy to do. This approach is referred to as "Parametric Modeling".
Re: Exhaust
Re: Exhaust
That's awesome David, blows my mind what can be done with the software these days....if you know what your doing
Tracker CNC 4x4
