Tangent snaps for drawing bracket
TJS wrote: Wed Sep 18, 2024 3:42 pm Hope all is well. I was looking at your "new guy" post where you drew up the simple bracket in inkscape.
You noted that nodes will need to be edited. I am in the process of drawing up something similar for my bull/push bar project. See my rough drawing. I am not good at attaching lines to a circle tangentally, I usually just draw a circle and do a union but there is always that little transition and it is not smooth. I am going to try and draw it up. Hopefully my node attaching skills will work. I also have trouble drawing a simple line with the bezier tool. Everytime I release the mouse to press enter the line is not straight.
TJ - Here are some screen shots showing the method I used. Hold down the Ctrl key while you are drawing your bezier line to keep it orthogonal. Use your Tangent snap to draw the line from the bottom to snap it to the circle. Then edit your circle (before Object to Path) using the round handles to make it a partial circle with the ends close to the ends of the sides. Zoom in to get it close (your snaps are off for this). Then select the partial circle and "Path, Object to Path" and in node edit mode joint the ends of the partial circle to the sides using the "Join selected nodes" tool.
tj 0.jpg (53.66 KiB) Viewed 1109 times
tj 4.jpg (24.02 KiB) Viewed 1110 times
Re: Tangent snaps for drawing bracket
TJS
Post by TJS »
Thanks David,
I am going to play with this and try and follow along. I have to remember that I need to weld in 10ga strips between two of these plates to make sort of a tube. Then weld this whole assembly to some straight tube so my sizing will be critical. Thanks so much for your help. I will post when I get there.
Thanks again.
T.J.
Joe Jones
Post by Joe Jones »
Is the arm 2"x3" rectangular? It would seem a lot easier to just use a length of 2"x3" rectangular tubing, drill the holes through where needed, and cut the two side flanges to allow the sides to follow the contour around the narrow tip.
PlasmaCam 4x4, Samson 510 table, Go Torch, + more
AD-AH-AM-AN-3D-CS-MU-PC - Upgrades
X-TOOL D1 PRO (x 4) F1, S1 (x3), P2 (x2), F1 ULTRA (x2) with conveyors, M1 ULTRA (x2) + accs.
50 Watt GALVO fiber
SwiftShape 3-in-1 machine
CreatBot D600 PRO
Stratasys Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
weldguy
Post by weldguy »
I like Fusion for mechanical designs like this. Fusion would make this SOOOO easy where as Corel, Inkscape, etc require creative thinking to make it happen.
TJS
Post by TJS »
Joe Jones wrote: Thu Sep 19, 2024 10:55 am Is the arm 2"x3" rectangular? It would seem a lot easier to just use a length of 2"x3" rectangular tubing, drill the holes through where needed, and cut the two side flanges to allow the sides to follow the contour around the narrow tip.
Yes Joe,
I thought about that.
I am going to lay this portion back a few degrees toward the grille of the truck.
I can think of several ways to accomplish this with Fusion 360. Here are two of them.
I don't know that either of these methods is necessarily easier than with Inkscape, CorelDraw, or some of the other programs. TJ was looking at an Inksacpe example I showed at another post and asked specifically about doing it using Inkscape node editing. There are other ways to do it with Inkscape that are quicker - here is one of them.
This is also pretty quick to do with CorelDraw.
It is also very easy to do with the eMachineShop desktop version. I am using one of the older free versions.
I think it all depends on one's proficiency level with a particular program (or programs). Also - many folks are used to using a certain cad drawing program that they may have been using for many years, and may not have any experience using some of the newer 3D type programs.
TJS wrote: Thu Sep 19, 2024 7:01 am Thanks David,
Thanks again.
T.J.
TJ - you are quite welcome! Whether you cut the profiles from the rectangular tube (as has been suggested) or cut individual pieces and weld together - you will still need to draw up the profile before you can cut it. i will look forward to seeing how your finished project turns out.
Return to “Inkscape”
