Hypertherm sync adapter
I have a Hypertherm 65 with a machine torch installed on my table, bought the sync adapter and fine cut cartridge to use. For some reason it doesn't seem to come up tight to the torch head and doesn't fire when commanded. Anybody have any advice or knowledge of the sync adapter?
Re: Hypertherm sync adapter
Are you using a Duramax torch?
That is very strange. Do you get a 0-50 error on your Powermax LCD screen with the adapter installed?
I think that’s the error, it doesn’t seem to come up tight like with the hand torch
Very strange. I would be interested in seeing a pic of it installed if you could snap one with your phone and post it.
Are you sure that you have your swirl ring removed before attempting to install the adapter?Tinner23 wrote: ↑Wed Sep 04, 2024 1:24 pm I have a Hypertherm 65 with a machine torch installed on my table, bought the sync adapter and fine cut cartridge to use. For some reason it doesn't seem to come up tight to the torch head and doesn't fire when commanded. Anybody have any advice or knowledge of the sync adapter?
Yeah, swirl ring was removed
Then I would contact your Hypertherm rep to find out what the problem is. I know that Robert has been using the Sync adapter on his Duramax torch with great success.
Ok, thanks
I am assuming you restarted the machine after installing? Funny question but sometimes start with the basics
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Durma Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
I put it on before I started the plasma and the table Haven’t messed with it lately but I’m going to soon
OK. On mine if the cartridge is taken off the plasma unit detects that even if the adaptor stays on
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
