Farm Scene Fire Ring
jmersereau
Post by jmersereau »
Here is a huge fire ring (18" x 119") that I found on this site from a post 14 years ago. It does not provide credit for the original creator.
Cows farm.dxf
I first removed some details, added some tabs and bolt holes and reduced it to 73"
73 Inch Farm Fire Ring.dxf
But, it was too big for me to cut. I made some more changes and separated it into two pieces (12" x 42" each)
Large Farm Fire Ring.dxf
If anybody knows who the original creator was please let us know, a lot of work went into this!
PrimeWeld CUT60
Langmuir CrossFire Pro
tinspark
Re: Farm Scene Fire Ring
Post by tinspark »
Pretty awesome.
The silo's and the pine/sequoia tree, just to the right of the silo's may not roll as well as the rest of it, (tall and skinny) and may remain flat and not roll like the rest of it if rolled in a slip roll type setup, since there is nothin substansial for the rolls to grab on to. Step braking in a press brake would get the flat spots out. A hand brake would work too but the sequence might be a little different. or a combo of the two machines. imo..
Thanks for sharing.
Also I like the two piece version, with the matching bolt slotted holes and tabs
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Nice work Jim! Depending on the thickness and slip-roll capacity, perhaps sandwich the cut part between two other sheets of thin material for rolling to keep everything intact.
cuttinparts
Post by cuttinparts »
Now that's awesome, well done Jim!
