scotch brite
Learn and share abrasive & texturing finishing techniques, experiences, and product knowledge here.
Dirtmotor
scotch brite
Post by Dirtmotor »
Has anyone tried using the scotch brite 4 1/2 angle grinder disks to clean up cold rolled 14 gauge ?
weldguy
Re: scotch brite
Post by weldguy »
I have and if your just looking to surface finish the part it will do a nice job but pointed edges and dross will tear them up pretty quick and i found them to be too expensive to put up with that.
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
tinspark
Re: scotch brite
Post by tinspark »
Dirtmotor wrote: Mon Jul 29, 2024 10:58 am Has anyone tried using the scotch brite 4 1/2 angle grinder disks to clean up cold rolled 14 gauge ?
yes, But I mainly have usd them to polish stainless steel.
when you say "cleaning up" it is kinda vague.....
I have also used a "cup brush"wire wheel on a ginder for flat sheets which does a nice job too for taking off rust and paint.
It snags on edges a little though, but not enough to be a problem
a stiff twisted wire wheel on a ginder and on edge takes a lot of stuff off too. But the wires break off the wheel ocassionaly and can penetrate skin if ran too fast. I always wear safety glasses and a face shield when I run one of those.
Not sure wha U are "cleaning up" on 14 gauge though.....
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
Thanks , I use a wire wheel and flap disks also , the wire wheel gets what little dross is there , then I use the flap disk to clean it up before I bead blast , The flap is pretty aggressave , so I saw the scotch brites and was wondering if they would work , I have 50 school logos to make and they do have some sharp points on them so sounds like a no .
tinspark
Re: scotch brite
Post by tinspark »
Give one a shot. They work pretty good to deburr as well, and would likely make light wok of the pointy metal.
I have two or three grinders set up all of the time. Maybe set up a few grinders and try the flap discs on the rough stuff and a schotch brite wheel on other areas that you want to make safer (sharp edges).
Also there are the old school sanding discs with a backer pad . 80 grit has been a go to of mine for medium work. 50 grit on for rough grinding. 120 grit on finish work. but the 120 grit wear down pretty fast
Doug,
Hypertherm 45XP-
Re: scotch brite
There are what I use to remove paint and mill scale, they work very well.
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
acourtjester wrote: Mon Jul 29, 2024 5:32 pm There are what I use to remove paint and mill scale, they work very well.
Thanks , I ordered some to try .
Re: scotch brite
I have used similar for years and they work well for the intended purpose.
Re: scotch brite
Also - here is the link for the product Tom has cited.
https://www.ebay.com/itm/145403883912?_ ... VF269JZC39
Re: scotch brite
Amazon appears to offer this same item at a much better price.
https://www.amazon.com/dp/B07X5XHLXF/re ... RhaWw&th=1
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
Thanks ,you would have saved me 12 dollars had I not already ordered them . I looked on amazon first I did not see them . Thats just my luck !
Re: scotch brite
Dirtmotor I did the same search on Amazon and that is why I when to eBay for the screen shot. :Sad :Sad Sometimes is comes down to the words used or which words the search engine reacts to. I have used both when looking for something and did a copy and paste to a search on the other site to see who has the better deal. I used eBay more as they show the shipping up front, but amazon will give free shipping when you buy enough and are not in a rush. Ebay does show a better description for the items.
Re: scotch brite
Tom - I like Amazon because they post user feedback for the products. If you have Amazon Prime, then probably 99% of the items are shipped for free. You do have to pay sales tax, same as on Ebay. Also - when the need arises returns are quicker and free with Amazon. Ebay not always so much. But if there is a better deal on Ebay - then I am happy to order from them as well.
Re: scotch brite
I am not complaining about Amazon, I seen to be using they more lately. I did have a problem with the last VFD I ordered the shipper posted a tracking number and it never was shipped. I contacted Amazon and they had another vender ship and corrected the sale action, so all is good. :Like
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
Following up , recieved the pads , I am using cold rolled 14 gauge . I thought it would save me time since I am makig 50 of the same thing , Sad to say it has not saved time .Still ended up doing a acid soak and flap disk .Main problem is the oil on the cold rolled . I can not seem to get it 100 percent off steel and it is causing defects in my powder coat , I am wiping steel then cutting out parts ,then acid soak, then a light flap disk , then tig welding a 3 foot stake on it then back to the flap disk to clean up welded area ,then a a acetone wipe down, then into blast cabinet ,then into oven for pre heat then out to cool then powdercoat and back into oven to bake , After all of that I still have some areas on some of them that has random areas where it appears like oil is bleading through , not sure what else I can try . The wheels that I bought work great except a black tar like substance comes out on parts and takes brake cleaner and a ton of elbow grease to remove . Sorry so wordy . any ideas on how I can shorten the process
Re: scotch brite
I have used these sort of pads more for paint removal on automotive parts, and have never used them on cnc plasma cut parts. I have not had good luck with the acid dip either. I use a combination of several different grit flap disks followed by da sander with #80 paper.
I did cut a bunch of gutter brackets last year for a friend from 11ga. CR steel. The sheet was clean with no rust and I gave them to him in bare metal to use as is.
Re: scotch brite
Wow Dirtmotor that some process you are doing to get a good finished product. Have you tried a pressure washer to clean the metal before you start any other process?? It could be the oil has gone deeper into the metal surface pours when processed at the mill. OHSA has removed many of the products that clean better . :Sad
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
acourtjester wrote: Wed Aug 07, 2024 9:29 am Wow Dirtmotor that some process you are doing to get a good finished product. Have you tried a pressure washer to clean the metal before you start any other process?? It could be the oil has gone deeper into the metal surface pours when processed at the mill. OHSA has removed many of the products that clean better . :Sad
Not this time , I think I will go back to hot roll , In hindsight I should have cleaned metal better .
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
This is the finished piece
Re: scotch brite
Nice selling like hot cakes????
Dirtmotor
Re: scotch brite
Post by Dirtmotor »
Dont know about pancakes but have an order for 50
Creative25
Re: scotch brite
Post by Creative25 »
I like to use scotch brite to polish stainless steel after removing dross with a flap disk.
If there is any dross they wear down really quick.
Re: scotch brite
Creative25 wrote: Tue Jan 21, 2025 5:44 am I like to use scotch brite to polish stainless steel after removing dross with a flap disk.
That's good to know! I use the red scotch bright pads for cleaning steel after welding, and have also used the red discs in the past as well - more for grinding away old paint and rust.
Return to “Abrasive & Texturing”
