Crosshair alignment for Laser Etchers
Topics related to laser engravers and laser cutters.
I posted a YouTube video about alignment of the crosshair led on a the Laser etcher/cutter. And also 3-D printed a adjustment know for the Z axis on the laser which makes it a little easier to use, attached is the STL file for the knob. This is for the Ikier brand.
printer knob BB.stl
https://youtu.be/U_c0n16dvfs
Re: Crosshair alignment for Laser Etchers
acourtjester wrote: Wed Jun 12, 2024 7:36 pm I posted a YouTube video about alignment of the crosshair led on a the Laser etcher/cutter. And also 3-D printed a adjustment know for the Z axis on the laser which makes it a little easier to use, attached is the STL file for the knob. This is for the Ikier brand.
printer knob BB.stl
Thanks for that Tom! I will take a look at your video and save your stl file for potential use once I have my identical laser etcher up and running. I'm just finishing up the cart. Built from 1 1/2" square 16 ga. tubing with 18 ga. galvanized steel shelves. The top will be plywood with probably a masonite cover (spoil board). I used one of my Rhino Carts to fixture it up for welding. Forgot to take pictures.
Nice cart something I added was a lower shelf to be used with the rotary attachment I bought for the laser. I can remove the spoil board layer and have the other below for the rotary, To do mugs, glasses, or round objects for gifts. I had one for my lower power laser and just added the one that ikier sells for the one we bought. I 3-D printed some leg sockets for the laser, so it just slipped into them for mounting the laser to the table base.
Also have another lower shelf for the power unit and air assist unit.
ikier leg mount.stl
https://www.youtube.com/watch?v=tz6XzFp ... serChannel
Tom- that's a great idea!! I will make my top layer/spoil board removable, so I could add that if necessary. I also wanted some where to locate the small air compressor unit - so I thought a lower shelf might be a good idea.
Tom - have you made any new projects lately with your Ikier? That knob looks interesting - I may just have to print one.
I have created some wedding date plaques for friends and family (one for the boss too)and a few funny plaques for fun. I had a custom hat made and sent the guy a thank you wall hanger. Using 3mm plywood from Amazon and Home Depot I made a gig so I can mount projects and have a standard starting point. Makes it easy to remount projects to made additional engraves and cuts.
Tom - great job on that hat! The finish looks great. I think I have seem some of the others before.
Thanks just having fun :Like :HaHa
CNC_rowdy
Post by CNC_rowdy »
Tom and David, sorry about the very late post, but all of your work here above looks like a great job. Maybe one day if you guys come up with design for the Z axis for a xTool D1 or D1 pro, I will be one of the first to buy one.
Tim
Go Torch 2x2 Table
Advanced Design Edge, Machine Control, Height Control
Snap & Cut Torch Holder
Hypertherm XP 45 Plasma Cutter & Machine Torch
Sorry but it is unlikely as the Ikier models we have already has a Z axis drive.
Return to “Laser Engravers & Cutters”
