I've been using Mach 3 for about 20 years but still far from being an expert and most of my experience has been with Mill, laser and router.
When something rotten happens during an operation I can usually just re-home and start again. (after obligatory swearing and changing broken cutters etc.)
Since plasma cutters don't take kindly to re-cutting a partially finished job (torch following previous cut, which is now just a gap of air)
What kind of strategies have you come up with to pick up where things went wrong?
Yesterday while getting some bugs out of a new plasma build I had a torch "no start". Mach 3 stops looking for arc ok.
I solved the issue by inspecting the torch and servicing the consumables and re-opening the cad program to delete the cuts already finished.
Anybody got any hints and tips on this?
Thanks all!
This forum is a lifesaver!, Glad I joined as a contributing member.
