Plasma Cutting Perforated metal??
DJC
Post by DJC »
Anybody draw a design for perforated metal? I am thinking of making some with 1/2" holes to be cut out of 18 gauge - not sure how I would cut it without it warping and twisting beyond recognition?? Thanks-
djreiswig
Re: Perforated metal??
Post by djreiswig »
You would have to move around a lot to keep from warping.
DJC
Post by DJC »
Yeah I was thinking cutting one hole at a time with a period of cool down in between each - would take forever...
weldguy
Re: Plasma Cutting Perforated metal??
Post by weldguy »
I think all you can do is get your speed tweaked so your going as quickly as you can and move around a lot as djreiswig says to spread the heat out more evenly. It may be worth trying a higher amperage at faster cut speeds on the 18g as it may actually put less heat into the material than lower amps and slower speeds.
djreiswig
Post by djreiswig »
Does plasmacam have a setting to reduce heat input into the material?
Francisco
Post by Francisco »
djreiswig:
"Does plasmacam have a setting to reduce heat input into the material?"
Yes, it does. You can configure path conversion to minimize either heat input or cutting time - it will establish the cutting sequence accordingly.
I've made a few parts with many perforations (drain covers, a plate for a vacuformer, ember trays..), it works fine. Also for groups of parts.
sonbakler
Post by sonbakler »
Francisco wrote: Tue Feb 21, 2023 2:44 pm djreiswig:
I had no idea that feature was built in! Thanks for mentioning this :Like :Like
