Powermax 45xp Arc Voltage Connection
bogger44
Post by bogger44 »
hi i bought a new 45xp without the cpc port do i need the voltage divider card in it or can i hook up internally like the pm 1000? where to hook up would be great too. Thanks
djreiswig
Re: powermax 45xp
Post by djreiswig »
Toward the bottom is a link for the instructions to connect to raw arc voltage. You don't need the kit, just hook to the internal terminals. This is assuming you are using raw arc voltage on your 1000.
https://www.plasmaspider.com/viewtopic.php?t=23117
Re: powermax 45xp
Connect as shown to monitor raw arc voltage. If you need a voltage divider, then wire it between the raw arc voltage cables and your thc.
Return to “CandCNC Forum”
