Hello,
Using Inkscape 1.0.1 , When I import a file Deer in scope
post by cguethert, all the nodes are broken into two nodes. I have ran into this before. How can I fix this?
DXF Import All Nodes Broken
Re: DXF Import All Nodes Broken
If you use the selecter tool and form a box around the whole image and then click on the path menu and go to combine and click on that it should connect all the nodes as one path.
You are the Man! Thank you!
