my powermax 85 quit working in the middle of a cut,and shows a 0-99 code...upon going thru it looking for an issue,it appears the fan is not working.i did some testing with the volt meter,and found there to be voltage at the fan,the fan shudders and tries to go,but will not run.i put power directly to the fan and it will not go,so im assuming that it is faulty.
does anyone know the best place to order a replacement fan,preferably in canada,but not necessary
powermax 85 code 0-99
Re: powermax 85 code 0-99
part number: 228686
Kit: Powermax65/85 fan subassembly
https://www.google.com/url?sa=t&source= ... SpPnTKWR2n
pdf page 232
actual part number (from fan manufacturer as hypertherm don't make fans) is
t12e48bs1m7
zoom in on image (aligns with others from bakergas for example)
pdf page 232
t12e48bs1m7
Thank you for the info...the link to the service manual will be very helpful
