Most of you are alot smarter then me when it comes to this kind of thing and I have spent days trying to figure this out and just seem to be running in circles.
I am using teknic servos and have the following choices in rpm (each has plenty of power and will not be a problem)
840 rpm
1,770 rpm
2,370 rpm
3,180 rpm
4,150 rpm
I will be using a 10:1 gearbox for better resolution
Where I get dizzy is in picking out a rack and pinion appropriate for (lets say 1200 ipm rapids)
http://www.apexdynamicsusa.com/lanotatt ... ion_1_.pdf
Can someone please look at this document and tell me which one would be appropriate for my setup?
Help Selecting Rack And Pinion
Re: Help Selecting Rack And Pinion
The rack is not really critical in terms of the design. I have found helical racks run more smoothly than straight cut racks.
But the pinion diameter deserves a bit of attention. Choose a pinion that gives you around 20mm to 30mm travel per motor revolution with your gearbox reduction.
So then pick a motor rpm that has good torque at your maximum cutting speed and still has enough top end to get to your chosen rapids
Thank you so much for the reply.
So if I choose the 1700rpm with a 25mm per inch gear and a 10:1 reduction I should get 177ipm rapids?
If that is the case then I am using 1,383 oz teknic servos
They also make a 2,370rpm (1,047 oz) motor if I benefit from faster rapids.
(I am building it so that it can support a heavy gantry since it will also be a cnc wood router which will have 3 spindles) I plan on swapping the z-axis attachment (one for wood and one for metal)
Forgive me for metric units but:
25mm diameter pinion gives 79mm linear travel per pinion rev
5:1 gear box with 30 m/min rapids ( 1180 ipm) Will give you a 1948 RPM. 20 m/min (800 pm) is well within reach
Going to a 10:1 gearbox and 12m/min rapids (470ipm) = 1533 rpm which might be doable (about 10% under max)
It kinda shows that the design parameters for plasma and routers are mutually exclusive. Router needs the bigger 10:1 reduction for better torque and plasma needs more velocity and acceleration so would be better with 5:1 reduction
So I might be better suited going with a 3180rpm motor
https://www.teknic.com/model-info/CPM-S ... voltage=75
I like the idea of having motors that are quicker then needed since most of the metal I cut will be thin gauge
If you were going to spend that sort of money, I'd get Clearpath to go over the engineering with you.
