Problems with file
Problems with file
I am trying to make this name sign. The top name, SOUCY, works out fine. I am having problems with the lower name, PAQUETTE, I would like it to sit on a bar like the top name. I can figure out how to do the Q in Paquette. I will normal just hit path difference, however, the tail of the Q disappears. Any help would be appreciated. Thanks in advance, Kieran
- Attachments
- soucypaquette2.svg
- (56.4 KiB) Downloaded 50 times
Re: Problems with file
I lookde at the file and the Paquette has a double line and all will all out.
Try replacing the Q with and O and then add a tail after to make it a Q place the letters on a line as above and the add the tail for the Q as a separate operation.
Will do. thanks.
