Sitting here for the last four hours making lines to try to finish resolving a thc issue and without fail, make the line width .0591 or even smaller and I'll be damned if sheet cam doesn't make it a rectangle which defeats the whole purpose behind the line.
A little help would be sweet.
Simple line turns into a rectangle
Re: Simple line turns into a rectangle
May help if you advise what file format you are importing into sheetcam?
DXF, SVG?
maybe post what you are trying to do
DXF, SVG?
