(Also I only need to cut 1 of each item and not 2)
Thank you acourtjester the only issue is that i don't have a the .SVG file for inkscape the download only had the .DXF file thats what I'm trying to work with. Unless this isn't possible I have yet to be able to open a .DXF file with inkscape without it saying an error occurred.acourtjester wrote: Sun Oct 06, 2019 6:36 pm If the file has those items like it is shown no, but a quick way is in Inkscape have the file displayed and then with the arrow pointer enabled pull a box around the group you want to cut and use copy and paste to a new Inkscape page and save it like that. Do each item you want a save it separately. Then in SheetCam do a import drawing of one, then use the new parts option and add another item. You then can mover each one with the contour function to nest them. It help when you bring in new items to tell SheetCam to place it in the middle of the table, that way you are not putting one on top of another. Add as many as you want this way.![]()
Thank you very much this was a great way to work around this this of issue. Took a little bit of time but I'm ok with that.acourtjester wrote: Sun Oct 06, 2019 8:01 pm What I do is open the DXF file in QCAD and save it as a R18 (2004/LT2004)DXF Drawing (Teigha) (*.dxf) chose your name and saved location.
That will open in Inkscape with the dimensions of the original file.I you open many DXF file in Inkscape the scale is way off sometime just junk.
QCAD is free just download it and have it for these types of operations.![]()
Thank you! I never knew this feature existed......just gave it a go and works like a champ.djreiswig wrote: Sun Oct 06, 2019 9:31 pm I've never used it, but there is a function in SheetCam I've seen Les talk about.
Right click on the job and select 'break up manually nested drawing. This will break the drawing into individual parts.
Worth a shot.
Thank you!!! Just used this post. Thanks for sharing this. Lifesaver!!!djreiswig wrote: Sun Oct 06, 2019 9:31 pm I've never used it, but there is a function in SheetCam I've seen Les talk about.
Worth a shot.
