Looping outside corners
TrinityFabworks
Post by TrinityFabworks »
Is there a way to loop outside corners in sheetcam? I can't figure it out for the life of me?
Re: Looping outside corners
Not sure if this is what you are looking for
robertspark
Post by robertspark »
as shown in the picture in the post below you need to tick the radio / selection button that says "arcs"
TJS
Post by TJS »
What does it actually mean: Loop Sharp corners. Does it mean put a radius on them.
I think it is a outside loop so the corner is a sharp angle, the loop is outside the part cut material.
Ironken
Post by Ironken »
TJS wrote: Tue Oct 01, 2019 1:28 pm What does it actually mean: Loop Sharp corners. Does it mean put a radius on them.
Are you looking to put radiuses on sharp corners? If so you can "fillet" the corners of the drawing in CAD. If that's the case, post up which CAD program you are using and maybe one of us can help you out.
JD2 MAD 4X4
Millermatic 252 (spray)
Millermatic 190 (short circuit)
Syncrowave 210
Powermax 65
Powermax 45xp
Grizzly Vertical Mill (junk)
Baileigh BS-210M
50t Press
Shitloads of DeWalt
robertspark
No it means make them sharp corners by looping the torch path as shown in the image below.
2019-10-01 20_07_33-SheetCam TNG Development - TestDrawing.png (18.59 KiB) Viewed 1093 times
If you want to create a radius on all of the corners (or some) what you can do is adjust your G64 tolerances if using Linuxcnc or UCCNC.... won't work for Mach3 ...... think it works for Mach4
http://linuxcnc.org/docs/2.6/html/gcode ... ml#sec:G64
TrinityFabworks
robertspark wrote: Tue Oct 01, 2019 3:10 pm
This is what I was looking for. Thanks!
TJS
Post by TJS »
Thanks for the image and explaination robertspark. This helps. Ironken, I do know how to radius the corners in Inkscape, thanks for that help.
Return to “SheetCam”
