Wierd problem
ranger11
Wierd problem
Post by ranger11 »
I have a home built table and have an issue that is driving me nuts. Any time I have the table power on( plasma on or off) and open my cpu or when selecting a file when loading in sheet cam my plasma starts blowing air like its gonna fire up, however it never does. Its either a glitch or interference. Just wondering if any one else has had this problem.
robertspark
Re: Wierd problem
Post by robertspark »
how are you controlling the plasma cutter and what software are you using
parallel port, smooth stepper, pmdx, etc??
mach3, mach4, candcnc, linuxcnc, etc???
how are you controlling the plasma cutter?
relay, optocoupler?
how is it wired?
normally open / normally closed contact, source or sink?
what plasma cutter is it?
make and model
please give us much info as possible....
ranger11
Re: Wierd problem
Post by ranger11 »
Parallel port, mach3,relay, I'll have to check how it's wired. Miller extreme 675 cutter with the cnc port. Thanks for the reply.
ranger11
Re: Wierd problem
Post by ranger11 »
It's normally open/source wiring
robertspark
Re: Wierd problem
parallel port can be a bit of an odd ball control arrangement (bear with me I am not trying to rubbish it).
(NFS / Art I believe) added the chargepump to Mach3 because the parallel port can suffer from occasional wobbles when the PC starts up and shuts down and ports and pins can flicker.
which is what I expect is happening here to you.
Basically the pins are toggling / flickering very fast that the torch starts to fire, but does not because the signal drops out before the torch can actually fire hence the air continues to flow for its timeout period.
PDF page 9/14 explains this:
ftp://machsupport.com/Docs/Mach3%20Setup%20Tutorial.pdf
One way to "fix" this is to use the chargepump signal via a second relay to control the plasma cutter and offer the correct level of safety to interrupt the plasma cutter signal if the parallel port is not getting the continuous pulse trane of a chargepump signal.
You can make your own chargepump circuit via various means,
eg: ftp://anonymous:guest@ftp.machsupport.c ... Safety.pdf
or:
http://wiki.linuxcnc.org/cgi-bin/wiki.p ... arge_Pumps
or you could buy one of these:
https://www.cnc4pc.com/c4-safety-charge-pump.html
Or one of the other ones from china / amazon
https://www.amazon.com/MACH3-Charge-Mod ... way&sr=8-1
ranger11
Re: Wierd problem
Post by ranger11 »
I believe thats the issue. Thank you for your suggestion.
