In the past I built a couple floating heads for my CNC plasma cutters using hardened V-rails and V-bearings.
Here is one for an IP60 hand torch mounted on my CNCCS.
Here is another for a Hypertherm machine torch for my KRMx02 machine.
I wanted to experiment a little with different rails systems so I could design a floating head that was easyer to build.
Here is one based on 8mm shafts and truck bearings. The kind of bearings used on a 3D printer.
It is for a IP60 torch.
It works pretty good, but....
The bearings are a little too sloppy so they do effect the cut quality.
I decided to up the bearings and shafts a notch by moving to 12mm fully supported shafts.
These truck bearings have both upper and side adjustments for adjusting the pre-load.
Once I get a system working to my satisfaction, I will do a full write-up.
Bow Hunter Antler Design
Download Design
Another Floating Head
1 post
• Page 1 of 1
Post by msimpson99 »
1 post
• Page 1 of 1
Jump to
- Welcome Center and Meet Our Sponsors
- ↳ Introduce Yourself
- DXF Design and Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table and Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Tracker CNC Forum
- ↳ Tracker CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- CAD-CAM and Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories and Tool Related Forums
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
