Getting a random Estop shutdown
Searchman
Post by Searchman »
Getting a random Manual E Stop shutdown when moving the Z Axis up or down with the Cutter off. Also during a cut it will turn on the red fault light on the Gecko 540 and Mach 3 displays " External E Stop Shutdown.
Re: Getting a random Estop shutdown
Check the attached image for the values in the box shown in General config.
e stop.JPG (46.54 KiB) Viewed 507 times
