I have very limited knowledge in SheetCam, I can usually mill drill and tap
and finish a part.
Using Mach4 on a mini mill.
I would like to speed things up by having the drill bit rapid travel in
the Z axis to just above the surface, and then drill at the feed rate.
Is this possible with SheetCam?
Drilling
Re: Drilling
By default SheetCam will rapid down to 0.5mm (0.020") above the start depth. It then feeds down from there.
Re: Drilling
Thanks Les,
I'll give it a try.
I'll give it a try.
