3/16" steel with 45XP and fine cut consumables
john527
Post by john527 »
does anybody have the setting that are working best for them using the 45XP and fine cut consumables while cutting 3/16" thick mild steel?
Thank You
Ironken
Re: 3/16" steel with 45XP and fine cut consumables
Post by Ironken »
10g MS is the thickest recommended material for the finecut consumables. That's probably why you are not finding specs on them.
john527
Post by john527 »
I just changed over to the standard consumables and got the job done, thanks
