Trouble shoot THC
seajinx
Trouble shoot THC
Post by seajinx »
What is the procedure (if any) to trouble shoot the THC, to confirm if it is bad or not. I'm sure some has touch on this before but I can seem to find where. I've used the search and haven't found any procedural way to determine if the THC needs to be replaced. Thank you in advance.
WyoGreen
Re: Trouble shoot THC
Post by WyoGreen »
What THC are you using?
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
tcaudle
Post by tcaudle »
This is not a primary hardware support forum. Its just users like yourself that mostly have file or cut issues.
Since you appear to have a Arclight table (I found it from som eof your other posts) I would contact them on how to troubleshoot the THC.
Failing that, you can contact the Support Forum of the THC manufacturer
In any case basic information is needed. Approximate age of the system. Model of the THC, what its doing, can you cut with the THC off
Baseline voltages while cutting.
seajinx
Post by seajinx »
I did find the problem, It was the Voltage divider board. Replaced and operation back to normal.
