Designing cones
pertneer
Designing cones
Post by pertneer »
I have seen a couple of people ask about getting a dxf file for cones on here a few times. I came across a free software to design cones that will output a dxf file. The software is free for download. The name of the software is Cone Calc by I-Logic software (I have no affiliation with company). It is really easy to use to generate the dxf file. I have not cut a file, but they look like they should work.
4'x8' CNC Plasma w/Water Table Running a Powermax 65 :D
CandCNC, Mach3, SheetCam, Millwrite Plasma V6
Re: Designing cones
This is great. I had a similar program years ago I used for making 2 stroke exhaust pipes but this is far better. Anyone looking to do custom lampshades etc will love this, very easy to use. Thanks for the info!
cncplasmaworkz
Re: Designing cones
Post by cncplasmaworkz »
thanks for info!
Re: Designing cones
Thanks for pointing this out! I just installed it and it works great.
Jason@bc
Re: Designing cones
Post by Jason@bc »
Oh yes this is a dandy to have, I have used this software lots, real simple to use.
tnbndr
Re: Designing cones
Post by tnbndr »
funny thing, I had a cone calc program that worked off a website and it just went dead awhile ago.
Downloaded this program and is a great replacement.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
