.25 Aluminum Settings
krism
Post by krism »
Could someone recommend settings for cutting .25 thick aluminum? I belong to a makers club and they are using a Torchmate 4x4' table with a Lincoln Plasma cutter. I think it's a 6800 if that sounds right?
Nobody there is an expert on the machine, at least nobody I've talked to.
They do have a fine tip. Will that work on .25 Aluminum?
There is a chart that lists the tip height, pierce delay etc. But nothing on the recommended Amps.
