G code issue
kbenz
G code issue
Post by kbenz »
I don't know if I changed a setting or what? when I run a new code on my plasma table (mach) the torch touches off, pierces and goes to the .060 cut height. but it stays locked there no matter the volts. If I run an older code it runs fine though.
Is there a setting somewhere?
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: G code issue
Look at the top lines of the 2 G-codes and see if you are using the same pot processor.
Look down the G-code and see if you have S10 after the pierce (turn off DTHC), S20 turns it back on.
kbenz
Re: G code issue
Post by kbenz »
Same processor
I don't see a s10 or s20 in either one though???
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
kbenz
Re: G code issue
Post by kbenz »
what is a GO4 PO.4 and GO4 PO.5? this is inconsistant
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
kbenz
Re: G code issue
Post by kbenz »
I see now the GO4 is a dwell
I changed my lead ins and outs from tangent(which I just started using) to arc and it ran fine
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Les Newell
Re: G code issue
Post by Les Newell »
That is really strange. I can't see how tangent leadins would affect the THC.
kbenz
Re: G code issue
Post by kbenz »
may just be coincidence
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
tcaudle
Re: G code issue
Post by tcaudle »
kbenz wrote:I don't know if I changed a setting or what? when I run a new code on my plasma table (mach) the torch touches off, pierces and goes to the .060 cut height. but it stays locked there no matter the volts. If I run an older code it runs fine though.
For the auto DTHC to turn on, the pierce height has to be (somewhat) higher than the cut height. If it does not turn on your Z goes nowhere after it hits cut height (.060)
kbenz
Re: G code issue
Post by kbenz »
I said it "pierces and goes to the .060 cut height"
I pierce at .150
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
kbenz
Re: G code issue
Post by kbenz »
it was coincidence, started more trouble. did a restart on computer everything started working again. got another computer on order now
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Return to “SheetCam”
