Open paths in Sheetcam
chrisctc
Post by chrisctc »
For some reason once I import my drawing into Sheetcam it will show open paths on various parts of the drawing. Can anyone check it out and maybe point me in the right direction on what I am messing up?
-Chris
SeanP
Re: Open paths in Sheetcam
Post by SeanP »
You can see in sheetcam if you zoom right in where the problems are, you have some gaps, a few stray lines coming off the shape in parts.
Is the text meant to be so jaggy? it's going to come out a bit rough I would say.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
WyoGreen
Post by WyoGreen »
What program are you designing the part in? Are you able to export the file as an svg rather than a dxf? If so, do so and see what it looks like in Sheetcam.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
sphurley
Post by sphurley »
HatchRanch.svg
You had so many open/duplicate paths I can see why you had issues.
Here is something to look at and change the font all you want.
HatchRanch.zip
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
tnbndr
Post by tnbndr »
If you are drawing this up yourself in a CAD program, learn to use object snaps. Draw a line from endpoint (snap) to endpoint(snap) instead of just drawing lines that look like they are close. It will help to eliminate your gap problems.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
chrisctc
Post by chrisctc »
Thanks for the help! I am using Hycad for drawing, it has to be something with that program. It seems to only cause a issue on anything I dont physically draw. Most of the sign is made up of crops from the Plasmaspider DXF file pack that comes with the membership but once it goes into Sheetcam it shows open paths all over, no clue why. Anytime I start from scratch and draw something it works perfect and I do use snaps all the time.
tnbndr
Post by tnbndr »
I have found lots of open issues with files from this site and others. As you state those are the problem files not yours.
If you open one of those files and zoom in you will find the same open paths that Sheet Cam does. I have spent lots of time correcting files to use but that is just part of the game.
Return to “SheetCam”
