Anyone done those with good results? Pics and how bad is the warping?
Should it be cut with water level as high as possible or covering half the part?
Pm45 vs 3/8" or 1/2" stainless
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
- Capstone
Re: Pm45 vs 3/8" or 1/2" stainless
stuff that thick probably won't warp. you will have some pretty bad dross-burn on the edges that will need grinding. Water covering or not covering won't matter or avoid that issue.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Maybe adapt some of these parameters to your 45?
- Attachments
- APPL_NOTE_809060r0_Powermax_F5_Cut_Charts.pdf
- (205.94 KiB) Downloaded 68 times
Good morning gentelmen
I have cut S/S just using nitrogen. The nitrogen came from a 'G' size bottle and leaves a good smooth clean edge. You have to use a high flow regulator as there is a lot of gas being used mainly for cooling. It does not leave the cut edge shiny, however leaves the edge 'dark blue' temper marks colour.
Overall it does work and I didn't change the cut data from book spec. The speed was the best cut speed.
