Edges rounded
rhinoplasma
Edges rounded
Post by rhinoplasma »
while ago I am noticing that the corners or edges are not coming out straight but more rounded on thinner materials at high speeds (according to the hypertherm charts) for example when trying to cut a triangle it looks almost like an oval
Some comments?
BladeRunner dragon cut DTCH II
floating head
Powermax 65
4x8 table
Sheet cam TNG
tcaudle
Re: Edges rounded
Post by tcaudle »
Increase the acceleration on XY axis
rhinoplasma
Re: Edges rounded
tcaudle wrote:Increase the acceleration on XY axis
Hello My friend, thank u for your support
How much I have to increase it? 20, 30, 50% ? I want to have an idea
tnbndr
Re: Edges rounded
Post by tnbndr »
When you create your operation look in the upper right corner for "loop sharp corners option" Play with those settings or look in the help section for application. Works for outside corners.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
urbnsr
Re: Edges rounded
Post by urbnsr »
Maybe check the constant velocity setting. Too aggressive setting might create this.
