Problem with Pronest 10 CNC output
highlandjeeper
Post by highlandjeeper »
My father-in law passed away just before Christmas, and in his memory I have drawn his signature with autocad to cut it from 3/16" MS and affix it to a stone above the creek looking over the yard at the family ranch. I use Pronest 10, and the problem I am having is on the sharp corners, the cut path that is output is making loops into the actual part I want to keep. I hav tried to convert the sharp cange of direction to a radius to give a defined line to follow, but this did not work. Any thoughts would be appreciated.
dreamer
Re: Problem with CNC output
Post by dreamer »
scale up the size before you convert it to a cut path then scale it to the size you want and cut.
highlandjeeper
dreamer wrote:scale up the size before you convert it to a cut path then scale it to the size you want and cut.
Good call. Never thought of that. I will give it a try tomorrow.
highlandjeeper
Worked awesome! Thanks again.
