Start point optimisation
BensPlasmaAu
Post by BensPlasmaAu »
I was wondering if anyone knew of a function in sheetcam where the start points could be placed to prevent warping of the plate being cut. I know I can change them myself to get this, and it may cause most jobs to double in time it takes to cut but it could help me prevent some warping over a large quantity of piercings.
Home built 3400 x 1400mm (11 and a bit X a bit over 4.5 feet)
Hypertherm Powermax 45
CandCNC Bladerunner IV
Some air dryer off the internet
Another water seperator I found unused on a shelf
Refrigerated air dryer
beefy
Re: Start point optimisation
Post by beefy »
Easy Ben,
in your jet cutting operation, go to the "cut path" tab. Then under the "cutting rules" section, select "minimise thermal distortion".
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
BensPlasmaAu
Hi Keith,
I've just gone to sheetcam and tried what you suggested. I have no rules in the drop down. Do I need to make a rule up? How do I do that or is there a place where I can download a rule set? Forgive me for being slow on the uptake.
davek0974
Post by davek0974 »
Load a job, double-click on an operation in the list, then go to cut-path tab and its in there :D
beefy
Post by beefy »
Hi Ben,
Sheetcams path rules are very different to this rule in the jet cutting operation box.
As Dave explained you have to have a part loaded then your cut operation(s) will appear. You then double click on the operation and the operation box will pop up.
You'll see also there's a box where you can tell Sheetcam what the minimum distance is between cuts, then Sheetcam will TRY and accomodate that.
Keith
LinuxCNC
Coreldraw 2019
BensPlasmaAu
Thanks Dave and Keith. I found it and I have set the tool path for 100mm distance and it seemed to work on the creen. Will try the cut on the weekend. Dammit I need a shed closer to home. This 45 minute drive is a bit shit when there is stuff to be done. Better than the 1hr 45minutes where the table was previously though.
Anyone know of an industrial unit I could use that's close to Hornsby NSW that costs $70 per week???? It's a long shot but hey, why the hell not ask.
Return to “SheetCam”
